You must first configure Custom Option Definitions. For more information, see Configure Custom Option Definitions for the DHCP Server.
- Select DHCP Server.
- Select the Subnet Custom Option Data tab.
- Select Insert.
- In Subnet IP, type the subnet network address.
- In Subnet Mask, type the subnet mask.
- In ID, type the DHCP code for the custom option.
- In Value, type the data value to assign to the custom option for this subnet.
- Select Insert
Subnet Custom Option Data Field Descriptions
Use the data in the following table to use the Subnet Custom Option Data tab.
| Name | Description |
Subnet IP |
Specifies the network address of the DHCP subnet. |
Subnet Mask |
Specifies the subnet mask for the DHCP subnet. |
ID |
Specifies the DHCP code that identifies the Custom Option. The code must be an integer in the range from 224 to 254. |
Value |
Assigns a data value to this Custom Option for use within this subnet. The value must use the data type that you configured in the Custom Option definition. |
