Default Settings
The following table shows the default settings for Switch Engine starting with version 31.6, and shows any changes that have been made to these settings and in what version these changes were made.
Table 1. Default Settings
Feature31.6 and later32.4 and later
1G behavior in 10G ports (5420 and 5520 series switches)Autoneg OFF for port when 1G optic is inserted in a 10G port
Account LockoutAfter 3 consecutive login failures, account is locked for 5 minutes. a
Auto-Discovery for Universal HardwareEnabled.
AVBDisabled.
BFD Strict Session ProtectionDisabled.
BGPDisabled.
BluetoothEnabled.
BOOTP RelayDisabled.
CDPEnabled.
Configuration auto saveDisabled.
Clear-flowDisabled.
DiagnosticsAdmin level privileges required to show diagnostics. a
DHCPDisabled.
DNS Cache Resolver and AnalyticsDisabled.
IPFIXDisabled.
IP NATDisabled.
EAPSDisabled.
EDPEnabled.
ELRPDisabled.
ESRPDisabled.
Extended Edge Switching (VPEX)Disabled.
ExtremeCloud IQEnabled
FECEnabled on Native 25Gb ports.
Identity ManagementDisabled.
IGMPEnabled, set to IGMPv2 compatibility mode.
IGMP SnoopingEnabled.
Image Integrity CheckDisabled.
IP Route CompressionEnabled.
ISISDisabled.
LLDPEnabled.
LogAdmin level privileges required to show log. a
Logging memory bufferGenerate an event when the logging memory buffer exceeds 90% of capacity. a
MAC SecurityDisabled.
MLDDisabled.
MLD SnoopingDisabled.
MPLSDisabled.
MSRPDisabled.
MSTPEnabled.
NetLoginAll types of authentication are disabled.
NTPDisabled.
ONEPolicyDisabled.
Policy rule modelHierarchical (Unless upgrading from 30.5 with a saved configuration set to access list.)
OpenFlowDisabled.
OSPFDisabled.
OVSDBDisabled.
PasswordsPlain text password entry not allowed. a
PIMDisabled.
PIM SnoopingDisabled.
PoE
Fast PoE
Perpetual PoE
Enabled.
Disabled.
Disabled.
RADIUSDisabled for both switch management and network login.
RIPDisabled.
RMONDisabled. However, even in the disabled state, the switch responds to RMON queries and sets for alarms and events.
sFlowDisabled.
SNMP serverDisabled. a
SSHDisabled.
Stacking-supportEnabled.Disabled for 5120, Extreme 7520, and 7720 only.
Stacking auto-discoveryEnabled.
STPEnabled.
SyslogDisabled.
TACACSDisabled.
TelnetEnabled. a
VPEX IP Multicast ReplicationBPE
VPLSAll newly created VPLS instances are enabled.
WatchdogEnabled.
Web HTTP serverEnabled. a
Web HTTPS serverEnabled. a
a If you choose enhanced security mode when initially setting up the switch or after running unconfigure switch all.
