PIM MLAG Rendezvous Point Enhancements
Version 33.5.2 adds support for configuring MLAG peers as PIM Rendezvous Points (RP), removing a limitation in multicast deployments.
Issue: Prior to this release, MLAG peers could not be configured as PIM RP (Rendezvous Point), limiting multicast routing design flexibility in high-availability MLAG topologies.
Resolution: MLAG peers can now be configured as PIM RP with full support for Candidate Bootstrap Router (CBSR) and Candidate RP (CRP) roles in PIM Sparse Mode environments.
Key Capabilities:
Configuration:
configure pim cbsr vlan <vlan_name>
configure pim crp vlan <vlan_name> <policy>
Both MLAG peers must be configured as CBSR and CRP for the feature to function properly. The existing BSR and RP election mechanisms operate normally in MLAG environments without modification.
Scope:
Not Applicable For:
Usage Details: The feature leverages PIM synchronization between MLAG peers to share multicast receiver information learned through PIM joins. This synchronization, implemented as part of the PIM MLAG Transit solution, ensures consistent multicast state across the MLAG pair.
Supported Platforms
All platforms.
