Configure Cluster Mode
Universal Compute Platform supports a stand-alone mode and a full-cluster mode. Stand-alone mode requires only one defined node, but a cluster can be deployed using multiples of three (for example, three, six, or nine nodes) depending on your resource requirements.
Configure only one node for stand-alone mode or configure a full cluster of nodes (using multiples of three).
  1. For Cluster Mode, select Standalone or Cluster.
  2. (Clusters only) From the Number of Nodes drop-down, select the number of nodes for the cluster.
  3. (Clusters only) From the Number of Availability Zones drop-down, select the number of zones that you want to deploy.
  4. Enter the ICC IP Address for each node.
    If you are deploying multiple availability zones, make sure that each ICC IP address falls under the zone where you want to deploy that node
  5. Select Next.
When using an ExtremeCloud™ IQ engine, you must configure a cluster of three or more nodes in multiples of three (for example, three, six, or nine nodes). ExtremeCloud IQ is not supported in stand-alone mode, requires a cluster, and does not support engine types other than ExtremeCloud IQ.
What to do Next
Configure Pod Network Information
