When using an ExtremeCloud™ IQ engine, you must configure a cluster of three or more nodes in multiples of three (for example, three, six, or nine nodes). ExtremeCloud IQ is not supported in stand-alone mode, requires a cluster, and does not support engine types other than ExtremeCloud IQ.
Deployment Health also provides best practice information for your Universal Compute Platform configuration. System Health checks are run against your configuration and operational setup to inform you of best practices.
Default route configuration
NTP settings are configured.
System backup is scheduled
VRRP interface is configured properly
Kubernetes nodes and HA cluster are healthy
Load balancing is configured
DNS settings are configured with Primary and Secondary DNS servers. In addition, DNS is able to resolve URLs successfully.
Inter-node connectivity (latency) is within acceptable limits
Fix all error conditions. You have the option to ignore warnings. They are provided to inform and encourage best practice configuration.
