Use this procedure to configure Universal Compute Platform as an SNMP
agent. You can use SNMPv2c or SNMPv3 to monitor the system using a Network
Management Station (NMS) server. Unless stated otherwise, all steps apply to both
SNMP versions.
For detailed information on the SNMP fields and
configuration options, see
SNMP Settings.
- Go to .
Select the SNMP tab.
Select the SNMP Mode from the following
options:
- Disabled—To disable SNMP, select this mode and then
select Submit.
- SNMPv2c—Select this mode to enable SNMPv2c. This mode
includes default public and private communities. You can use the
defaults or assign new settings.
- SNMPv3—Select this mode to enable SNMPv3. This mode
includes an autogenerated Engine ID. You can use the default ID or assign a new
value.
(SNMPv3 only). Enter a Context String.
(SNMPv3 only). Configure SNMP Users:
Select Add User.
Enter a Name for the
user.
Select a Security level for
SNMP messaging for this user:
- Authentication, Privacy
- Authentication, No Privacy
- No Authentication, No Privacy
If the selected security level includes
authentication, select an Auth Type and enter an Auth Password.
privacy, select a Privacy
Type and enter a Privacy
Password.
Select Save to save the user
configuration.
Configure up to two SNMP notifications:
Select Add
Notification.
Select a Name for the
notification.
For Server Address, enter
the IP address of the NMS server.
For Server Port, enter the receiving port on the
NMS server.
notification.
From the Forward Traps tab, select the
severity threshold for the sending of SNMP messages to the NMS server.
Select Submit to save the SNMP
configuration.
To edit settings for an existing SNMP
community, user, or notification, or to update an authentication or privacy password
for an existing user, select the adjacent
icon,
configure the new settings, and select
Save.
Optionally, you can download a MIB resource
package zip file from the Extreme Networks Support Portal. You can upload the MIBs
to an NMS server and track application status using SNMP.
