| Field | Description |
| Name | Name of the interface. |
| Mode |
Describes how traffic is forwarded on the interface topology. Options
are:
| VLAN ID | ID for the virtual network. |
| Tagged |
Indicates if the interface tags traffic. When traffic is tagged, the VLAN ID is inserted into the packet header to identify which VLAN the packet belongs to. Tagging can identify the port or interface to send a broadcast message to. |
| Port | Physical port on the Universal Compute Platform for the interface. |
| Management Traffic |
Enable or disable Management Traffic through this interface. Enabling management provides access to SNMP (v1/v2c, v3), SSH, and HTTPs management interfaces. |
| MTU | Maximum Transmission Unit (MTU). Standard is 1500 bytes. Fixed value. |
| IP Address | For an Admin topology, the Layer 3 check box is selected automatically. The IP address is mandatory for a Physical topology. This allows for IP Interface and subnet configuration together with other networking services. |
| CIDR | CIDR field is used along with IP address field to find the IP address range. |
| FQDN | Fully-Qualified Domain Name |
| VRRP | This field lets you
assign VRRP virtual IP addresses to this interface. For
Managed Orchestration clusters, VRRP addresses support load
balancing and high availability for cluster services. For
Self-Orchestration standalone clusters, VRRP can be used to
create an IP alias with access to the application management
interface. To add a VRRP address, select Add, and configure the following:
Note: The Priority and Router ID settings are important in
multi-node clusters only. For Self-Orchestration standalone clusters, assign numeric values
to each, but the specific values are not important.
