auto-create-rfd-template
Enables auto creation of an RF Domain:
- when tokens are used to select the RF Domain to apply to devices matching the adoption
criteria, and
- the token-specified RF Domain does not exist.
During device adoption, if the token-specified RF Domain (configured using the ‘adopt‘
rule) is not found, the system auto creates a new RF Domain based on an existing RF Domain
template specified using this command. This option is disabled by default.
- Access Points — AP505i, AP510i/e,
AP560i/h
- Service Platforms
— NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
auto-create-rfd-template <RF-DOMAIN-NAME>
Parameters
| auto-create-rfd-template <RF-DOMAIN-NAME> |
Auto creates a new RF Domain based on an existing RF Domain
template
- <RF-DOMAIN-NAME> – Specify the RF Domain name (should
be existing and configured). The new RF Domain created is
saved with the token name specified in the ‘adopt‘
command.
The following example configures an adopt rule for adopting any AP7532 and applying an RF
Domain matching the token “$MODEL[1:5]” to the adopted
AP:
nx9500-6C8809(config-auto-provisioning-policy-test)#adopt ap7532 precedence 20
rf-domain $MODEL[1:5] any
nx9500-6C8809(config-auto-provisioning-policy-test)#show context
auto-provisioning-policy test
adopt ap7532 precedence 20 rf-domain $MODEL[1:5] any
The following example enables auto creation of an RF Domain using an existing RF Domain
‘rfd-AP‘ as template:
- RF Domain name “AP-75”: Applicable to any AP 7532
nx9500-6C8809(config-auto-provisioning-policy-test)#auto-create-rfd-template AP-75
adopt ap7532 precedence 20 any
auto-create-rfd-template rfd-AP
As per the above configurations, when an
AP 7532 comes up for first-time adoption, the system:
- Checks for an RF Domain matching the options provided in the ‘adopt‘ rule, and
if not found
- auto creates the RF Domain only if:
- A token is specified in the ‘adopt‘ rule. For example, $MODEL[1:5], and
- the ‘auto-create-rfd-template‘ option is configured
- Uses the ‘RF Domain‘ specified in the auto-create-rfd-template command as a
template. Therefore, the specified RF Domain should be existing and
configured.
- Applies the new RF Domain to the AP.
Related Commands
| no |
Disables auto creation of an RF Domain |
