ip-address-type [ipv4|ipv6]
ip-address-type ipv4 [double-nat|not-available|port-restricted|port-restricted-double-nat| port-restricted-single-nat|public|single-nat|unknown]
ip-address-type ipv6 [available|not-available|unknown]
| ip-address-type ipv4 | Configures the IPv4 address type availability information |
| double-nat | Specifies double NATed private IPv4 address is available |
| not-available | Specifies IPv4 address is not available |
| port-restricted | Specifies port-restricted IPV4 address is available |
| port-restricted-double-nat | Specifies port-restricted IPv4 address and double NATed IPv4 address is available |
| port-restricted-single-nat | Specifies port-restricted IPv4 address and single NATed IPv4 address is available |
| public | Specifies public IPv4 address is available |
| single-nat | Specifies single NATed IPv4 address is available |
| unknown | Specifies no information configured regarding the IPv4 address availability |
| ip-address-type ipv6 | Configures the IPv6 address type availability information |
                         available  |
                     Specifies IPv6 address is available |
                         not-available  |
                     Specifies IPv6 address is not available |
                         unknown  |
                     Specifies no information configured regarding the IPv6 address availability |
rfs4000-229D58(config-passpoint-policy-test)#ip-address-type ipv6 available
         rfs4000-229D58(config-passpoint-policy-test)#show context hotspot2-policy test access-network-type chargeable-public connection-capability ip-protocol 2 port 10 closed domain-name TechPubs hessid 00-23-68-88-0D-A7 ip-address-type ipv6 available 3gpp mcc 310 mnc 970 3gpp mcc 505 mnc 14 rfs4000-229D58(config-passpoint-policy-test)#
| no |
                         Removes the IP address type configured for this passpoint policy  |
