Warning
Power down the integrated services platform and disconnect all power cords prior to installing or replacing the Network Mezzanine Card (NMC).Caution
The NMC module uses lasers. The lasers are compliant with the requirements for a Class 1 laser product and are inherently eye safe in normal operation. However, you should never look directly at any visible laser when the module is operational.To install an NMC:
Caution
Ensure that the connectors on the back of the NMC do not come into contact with your hands or the packing material as you unpack the NMC. Avoid damaging the connectors as you insert the NMC into the integrated services platform.
