NX-7530 Integrated Services Platform Disc Drive Assembly
Replacement
Warning
Power down the integrated services platform and disconnect all
power cords prior to installing or replacing the disc drive.
The NX-7530 integrated services platform configuration includes a hard drive disc
assembly and Redundant Array of Independent Disks (RAID).
To replace a disc drive assembly:
Remove power from the integrated services
platform.
Press the release button on the right side of the disc drive assembly to
release the assembly lock.
Pull the hard drive handle to the left and remove the hard drive from the drive
bay.
Firmly insert the new disc drive assembly into the drive bay.
Push on the disc drive assembly until the lever locks in place.
Apply power to the integrated services platform.
When the new disc drive assembly is properly installed, the system
rebuild will launch automatically. This process may take up to two hours. To
monitor the progress of the system rebuild, login to the Command Line Interface
(CLI) and enter the show raid command to display the current
status.
