Caution
There are no user-serviceable components inside the NX-5500. Opening the chassis will void the warranty.
Caution
BIOS settings on the NX-5500 should not be changed. Changing any settings in the BIOS will void the warranty on the integrated services platform.
Caution
To prevent the NX-5500 from overheating, never install in an enclosed area not properly ventilated or cooled. For proper airflow, keep the front and back sides of the NX-5500 clear of obstructions and away from the exhaust of other equipment.
Caution
The recommended operating temperature is 32ºF to 104ºF/0ºC to 40ºC. Installation in a closed or multi-rack assembly may raise the immediate ambient temperature above the average room temperature. Exercise due caution.
Caution
Ensure the electrical circuit through which the NX-5500 is powered can safely accommodate a 100 Watt power supply.
Caution
It is recommended you connect the NX-5500 to an Uninterruptible Power Supply (UPS). There are instances in which the system software could become corrupt and un-recoverable in the event of power loss, for example, during a system upgrade, database backup or database restore operation.
