The Redundant Management Interface feature provides fault tolerance for the management path.
Redundant Management is supported on the SLX 9250 and the SLX 9740.device# configure device(config)# hardware device(config-hardware)# connector 0/15 device(config-connector-0/15)# device#
device(config-connector-0/15)# breakout mode 4x1G device(config-connector-0/15)# end device#
device# configure device(config)# interface Ethernet 0/15:1 device(config-hardware)# connector 0/15 device(conf-if-eth-0/15:1)# redundant-management enable device(conf-if-eth-0/15:1)# no shut device(conf-if-eth-0/15:1)# end device#
