This task performs a basic installation, removal, and re-installation of TPVM.
Switch to the Linux shell from the SLX-OS CLI.
Enter the Linux admin user shell.
[admUser@SLX]# su
password: <password>
The default password is "fibranne".
Remove the existing TPVM package at the following path in the device's SLX-OS VM, at the Linux shell login prompt.
[admUser@SLX]# rm -rf /tftpboot/SWBD2900/vm-swbd2900-*.deb
Using SCP or FTP, copy the new TPVM package that is compatible with the SLX-OS release from the release server, and copy it to the SLX-OS VM
/tftpboot/SWBD2900/ folder.
Return to the SLX-OS CLI shell.
Stop TPVM if it is running.
Uninstall existing TPVM firmware.
Re-install appropriate TPVM firmware.
Once the new TPVM image is running, you can download user-specific applications by copying them to the TPVM partition and starting them manually.
