The .get_output function returns—as a list—the output of the SLX-OS CLI commands assigned to a Python object.
Running this script displays the "Firmware name" line of the show version command.
#Required in all scripts for SLX:
from CLI import CLI
# Import the Python Regular Expressions (re) module:
import re
# Create Python objects:
slot_firmware = {}
cmd_show_ver = CLI("show ver", False)
# Using .get_output(), assign the result of show ver to a Python object named output:
output = cmd_show_ver.get_output()
for line in output:
found = re.search(r'^(Firmware name:)\s+(\S+)$', line, re.M)
if found:
slot_firmware[found.group(1)] = found.group(2)
print("FIRMWARE:\n")
for key in slot_firmware:
print("\t", key, "\t=> ", slot_firmware[key])
A log upon running get_output.py was as follows:
device# python get_output.py FIRMWARE: Firmware name: 20.1.1_190404_0333
