Configuring a native VLAN on a trunk port
Ensure that reserved VLANs are not used.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
    device(config)#
  2. Enter the interface ethernet command to configure the interface mode.
    device(config)# interface ethernet 0/1
  3. Enter the switchport command to set the interface as switchport.
    device(conf-if-eth-0/1)# switchport
  4. Enter the switchport trunk native-vlan command to set native VLAN characteristics to access and specify a VLAN.
    device(conf-if-eth-0/1)# switchport trunk native-vlan 300
This example removes the configured native VLAN on the Ethernet interface.
device(conf-if-eth-0/1)# no switchport trunk native-vlan 300
