virtual-machine
Displays the virtual-machine
(VM) configuration, logs, and statistics
- Service Platforms — NX 95XX, NX 96XX
Syntax
show virtual-machine [configuration|debugging|export|statistics]
show virtual-machine [configuration|statistics] {<VM-NAME>|team-urc|team-rls|
team-vowlan} {(on <DEVICE-NAME>)}
show virtual-machine debugging {level|on}
show virtual-machine debugging {level [debug|error|info|warning]} {on <DEVICE-NAME>}
show virtual-machine export <VM-NAME> {on <DEVICE-NAME>}
show virtual-machine [configuration|statistics] {<VM-NAME>|adsp|team-cmt}
Parameters
| virtual-machine |
Displays the following VM-related information: configuration or
statistics |
| configuration |
Displays detailed VM configuration |
| statistics |
Displays VM statistics |
| [<VM-NAME>| team-urc|team-rls| team-vowlan] |
The following keywords are common to the ‘configuration‘ and
‘statistics‘ parameters:
- VM-NAME> –
Optional. Displays VM configuration or statistics for the virtual
machine identified by the <VM-NAME> keyword. Specify the VM
name.
- team-urc – Optional.
Displays TEAM-URC (IP-PBX) VM configuration/statistics
- team-rls – Optional.
Displays TEAM-RLS (Radio Link Server) VM
configuration/statistics<
- team-vowlan –
Optional. Displays TEAM-VoWLAN (Voice over WLAN) VM
| on <DEVICE-NAME> |
Specifies the name of the device on which the command is executed
- <DEVICE-NAME> –
Specify the name of the service platform.
| virtual-machine |
statistics |
| configuration |
| statistics |
| [<VM-NAME>|adsp| team-cmt] |
- VM-NAME> –
name.
- adsp – Optional.
Displays Air-Defense Services Platform (ADSP) VM
- team-cmt – Optional.
Displays TEAM-CMT VM configuration/statistics
| on <DEVICE-NAME> |
- <DEVICE-NAME> – Specify the name of the service platform.
show virtual-machine debugging {level[debug|error|info|warning]}
{on <DEVICE-NAME>}
| virtual-machine |
statistics |
| debugging |
Displays VM debugging logs |
| level [debug| error|info|warning] |
Optional. Displays VM debugging logs based on the level selected. The
available options are:
- debug – Displays VM
logs of level debug and above
- error – Displays VM
logs of level error
- info – Displays VM
logs of level Info and above
- warning – Displays
logs of level warning and above
| on <DEVICE-NAME> |
- <DEVICE-NAME> –
| virtual-machine |
statistics |
| export |
Displays VM configuration export related information |
| <VM-NAME>] |
Displays VM configuration export related information for the virtual
name. The NX 95XX and NX 96XX series service platforms will display ADSP and TEAM-CMT VM
configuration export information.
| on <DEVICE-NAME> |
- <DEVICE-NAME> –
nx9500-6C874D#show virtual-machine statistics
NAME STATE VCPUS MEM (MB) BRIDGE-IF IP
WiNG - - 18432 - -
adsp Halted - - unknown -
team-cmt Halted - - unknown -
nx9500-6C874D#
nx9500-6C874D#show virtual-machine configuration
NAME AUTOSTART MEMORY(MB) VCPUS
WiNG - 18432 -
adsp ignore 12000 12
team-cmt ignore 1024 1
nx9500-6C874D#
nx9500-6C874D>show virtual-machine statistics adsp
VM name: adsp
Base Version : unknown
Install Status : not_installed
nx9500-6C874D>
