terminal
Sets the length and width of the CLI display window on a terminal
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.
Syntax
terminal [length|width] <0-512>
Parameters
length <0-512>
Sets the number of lines displayed on a terminal window
  • <0-512> – Specify a value from 0 - 512.
width <0-512>
Sets the width (the number of characters displayed) of the terminal window
ap505-13403B#show terminal
Terminal Type: xterm
Length: 0     Width: 80
ap505-13403B#
ap505-13403B#terminal length 30
ap505-13403B#terminal width 100
Length: 30     Width: 100
ap505-13403B#
Related Commands
no Resets the width or length of the terminal window
