Switch Model | Interfaces |
5320-16P-4XE |
16 x 10/100/1000BASE-T 802.3at (30W) ports
4 x 1/10Gb SFP+ uplink ports (includes 2 x Stacking ports)
1 x Serial console port (RJ-45) 1 x USB A port 1 x USB Micro-B console port |
5320-16P-4XE-DC |
5320-16P-2MXT-2X | 16 X 10/100/1000BaseT full/half duplex ports with 802.3at
Type 2 PoE+ (30W)
2 x 10GBase-T (1Gb/2.5Gb/5Gb/10Gb capable) ports (includes 2x Stacking ports) 2 x 1Gb/10Gb SFP+ ports (includes 2 x Stacking ports) 1 x Serial console port (RJ-45) 1 x USB A port 1 x USB C serial console port |
5320-24T-8XE |
24 x 10/100/1000BASE-T ports
8 x 1/10Gb SFP+ uplink ports (includes 2 x Stacking ports)
5320-24P-8XE |
24 x 10/100/1000BASE-T 802.3at (30W) ports
5320-48T-8XE |
48 x 10/100/1000BASE-T ports
5320-48P-8XE |
48 x 10/100/1000BASE-T 802.3at (30W) ports
5320-24T-4X-XT |
4 x 1/10Gb SFP+ uplink ports (includes 2 x Stacking ports) 1 x Serial console port (RJ-45) 1 x 10/100/1000BASE-T out-of-band management port 1 x USB A port 1 x USB Micro-B console port 0°C to 60°C operating temperature range |
5320-24T-24S-4XE-XT |
24 x 100Mb/1Gb SFP uplink ports
Switch Model | Weight | Physical Dimensions |
5320-16P-4XE | 3.0 kg (6.6 lb.) |
Height: 43.9 mm (1.7 in.) Width: 309.9 mm (12.2 in.) Depth: 299.7 mm (11.8 in.) |
5320-16P-4XE-DC | 3.0 kg (6.6 lb.) | |
5320-16P-2MXT-2X | 66.4 kg (146.3 lb.) | Height: 43.2 mm (1.73 in.) Width: 238.2 mm (9.38 in.) Depth: 270.0 mm (10.64 in.) |
5320-24T-8XE | 3.7 kg (8.2 lb.) |
Height: 43.2 mm (1.7 in.) Width: 439.4 mm (17.3 in.) Depth: 279.4 mm (11.0 in.) |
5320-24P-8XE | 4.0 kg (8.8 lb.) | |
5320-48T-8XE | 4.2 kg (9.3 lb.) | |
5320-48P-8XE | 5.0 kg (11.0 lb.) | Height: 43.2 mm (1.7 in.) Width: 439.4 mm (17.3 in.) Depth: 330.20 mm (13.0 in.) |
5320-24T-4X-XT | 3.2 kg (7 lb.) |
Height: 43 mm (1.7 in.) Width: 441 mm (17.3 in.) Depth: 254 mm (10.0 in.) |
5320-24T-24S-4XE-XT | 4.0 kg (8.8 lb.) |
Rack Mount Kits | Weight | Physical Dimensions |
XN-2P-RMKIT-006 (for models 5320-48T-8XE, 5320-48P-8XE, 5320-24T-8XE, and 5320-24P-8XE) | 0.2 kg (0.44 lb.) | Height: 20.3 mm (0.8 in) Width: 43.2 mm (1.7 in) Depth: 50.8 mm (2 in) |
XN-2P-RMKIT-007 (for models 5320-16P-4XE and 5320-16P-4XE-DC) | 0.52 kg (1.15 lb.) | Height: 50.8 mm (2 in) Width: 85.6 mm (3.4 in) Depth: 88.1 mm (3.5 in) |
XN-2P-RMKIT-011 (for models 5320-16P-4XE and 5320-16P-4XE-DC.) | 0.16 kg (0.35 lb.) | Height: 43.4 mm (1.7 in) Width: 50.8 mm (2 in) Depth: 85.6 mm (3.4 in) |
XN-2P-RMKIT-012 (for model 5320-16P-2MXT-2X) | 8.55 kg (18.8 lb.) | Height: 58.9 mm (2.32 in) Width: 123.1 mm (4.85 in) Depth: 160 mm (6.3 in) |
XN-DIN-MT-002 (for model 5320-16P-2MXT-2X) | 0.77 kg (1.7 lb.) | Height: 28.9 mm (1.14 in) Width: 75.9 mm (2.99 in) Depth: 104.1 mm (4.1 in) |
XN-UTMKIT-001 (for model 5320-16P-2MXT-2X) | 10.9 kg (24.1 lb.) | Height: 28.9 mm (1.14 in) Width: 75.9 mm (2.99 in) Depth: 104.1 mm (4.1 in) |
XN-WMKIT-002 (for model 5320-16P-2MXT-2X) | 2.97 kg (6.6 lb.) | Height: 28.9 mm (1.14 in) Width: 75.9 mm (2.99 in) Depth: 104.1 mm (4.1 in) |
