5320 Series Hardware Installation Guide
> EMC Warnings
Extreme Networks, Inc. March 01, 2025
Preface
Audience
New in this Guide
5320 Series Overview
5320-48T-8XE Switch Features
5320-48P-8XE Switch Features
5320-24T-8XE Switch Features
5320-24P-8XE Switch Features
5320-16P-4XE Switch Features
5320-16P-4XE-DC Switch Features
5320-16P-2MXT-2X Switch Features
5320-24T-4X-XT Switch Features
5320-24T-24S-4XE-XT Switch Features
Redundant Power Supplies for Use with Your Switch
Expansion Modules
LRM/MACsec Adapter
Maximum Capacity for Using the LRM/MACsec Adapter
Limitations for Some Optical Devices
LRM/MACsec Adapter LEDs
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Requirements for PoE Devices
Power Supply Requirements
Power Cord Requirements
Select a UPS
Build Stacks
Introduction to Stacking
Build Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
SummitStack Terms
Plan to Create Your Stack
Enable and Disable the Stacking-Support Option
Recommendations for Placing Switches for Stacked Operation
Recommendations for Configuring Stacks
Combine Switches from Different Series
Select Stacking Cables
Use the Extreme Stacking Tool
Set up the Physical Stack
Connect the Switches to Form the Stack Ring
Examples of Valid Stacking Configurations
Example: Basic Stack with Four Switches
Example: Basic Stack with Eight Switches
Example: Stacked Switches across Several Racks
Connect Your Stack to the Management Network
Install Your Switch
Mount the Device
Install an External Redundant Power Supply
Install Optional Components
Turn on the Switch
Log In for the First Time on Switch Engine
Configure a VLAN and a Virtual Router to Use a Front Panel Port for Local Management
Change the Switch OS via the Bootloader Menu
Change the Switch OS via the Startup Menu
Log In for the First Time on Fabric Engine
Remove and Replace Components
Remove a Device from a Two-Post Rack
Disconnect the RPS Cable and the AC Power Cord
Monitor the Switch
5320 Series Switch LEDs
External Redundant Power Supply LEDs
Technical Specifications
5320 Series Technical Specifications
Acoustic Noise and Fan Speed
Memory
Mean Time Between Failure (MBTF)
Power Specifications
LRM/MACsec Adapter Technical Specifications
Environmental
Standards
Console Connector Pinouts
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
Korea EMC Statement
EMC Warnings
Taiwan BSMI Warning
China CQC Warning
