| Switch Model | Interfaces |
| 5520-24T |
| 5520-24W |
| 5520-48T |
| 5520-48W |
| 5520-12MW-36W |
| 5520-48SE |
| 5520-24X |
| 5520-24T-ACDC |
| 5520-48T-ACDC |
| 5520-24X-ACDC |
| 5520-48SE-ACDC |
| 5520-VIM-4X |
| 5520-VIM-4XE |
| 5520-VIM-4YE |
** 100M on 5520-24x and 5520-24x-ACDC access ports supported with Switch Engine and with Fabric Engine. Refer to the Extreme Optics Compatibility Tool.
Switches
| Switch Model | Weight* | Physical Dimensions | |
| Chassis Only | With PSU | ||
| 5520-24T | 5.54 kg (12.21 lb.) |
Height: 44 mm (1.73 in.) Width: 441 mm (17.36 in.) Depth: 442 mm (17.42 in.) |
Height: 44 mm (1.73 in.) Width: 441 mm (17.36 in.) Depth: 449 mm (17.68 in.) |
| 5520-24W | 6.25 kg (13.78 lb.) | ||
| 5520-48T | 5.76 kg (12.70 lb.) | ||
| 5520-48W | 6.06 kg (13.36 lb.) | ||
| 5520-12MW-36W | 6.33 kg (13.96 lb.) | ||
| 5520-48SE | 5.70 kg (12.57 lb.) | ||
| 5520-24X | 6.25 kg (13.78 lb.) | ||
| 5520-24T-ACDC | 5.15 kg (11.35 lb.) |
Height: 43 mm (1.71 in.) Width: 431 mm (16.98 in.) Depth: 442 mm (17.42 in.) |
Not applicable |
| 5520-48T-ACDC | 5.95 kg (13.12 lb.) | ||
| 5520-24X-ACDC | 5.68 kg (12.52 lb.) | ||
| 5520-48SE-ACDC | 5.91 kg (13.03 lb.) | ||
VIM Modules
| Model | Weight | Physical Dimensions |
| 5520-VIM-4X | 0.17 kg (0.37 lb.) |
Height: 40.8 mm (1.61 in.) Width: 48.8 mm (1.92 in.) Depth: 146.3 mm (5.76 in.) |
| 5520-VIM-4XE | 0.20 kg (0.44 lb.) | |
| 5520-VIM-4YE | 0.21 kg (0.46 lb.) |
Power Supplies
| 10953 (350W AC) | 1.08 kg (2.38 lb.) |
Height: 82.5 mm (3.25 in.) Width: 40 mm (1.57 in.) Depth: 287 mm (11.30 in.) |
| 10951 (715W AC) | 1.16 kg (2.56 lb.) | |
| 10941 (1100W AC) | 1.16 kg (2.56 lb.) | |
| XN-ACPWR-2000W-F (2000W AC) | 1.16 kg (2.56 lb.) |
Height: 75 mm (2.95 in.) Width: 40 mm (1.57 in.) Depth: 292 mm (11.50 in.) |
| XN-ACPWR-550W-FB | 0.81 kg (1.79 lb.) |
Height: 40 mm (1.58 in.) Width: 73.7 mm (2.90 in.) Depth: 185.2 mm (7.29 in.) |
| XN-ACPWR-550W-BF | 0.81 kg (1.79 lb.) | |
| XN-DCPWR-550W-FB | 0.81 kg (1.79 lb.) | |
| XN-DCPWR-550W-BF | 0.81 kg (1.79 lb.) |
| Description | |
| XN-RJ45-DB9-CONSOLE-CBL | RJ45 to DB9 Console cable (6ft) |
| XN-RJ45-USBA-CONSOLE-CBL | RJ45 to USBA Console cable (6ft)* |
| XN-RJ45-USBC-CONSOLE-CBL | RJ45 to USBC Console cable (6ft)* |
* The cable might require a FTDI software driver on some operating systems.
