Replace Versatile Interface Modules
5520 Series switches support the following versatile interface modules (VIMs):
5520-VIM-4X versatile interface module that provides four 10-GbE (SFP+) ports.
5520-VIM-4XE versatile interface module that provides four 10-GbE (SFP+) ports, LRM/MACsec capable.
5520-VIM-4YE versatile interface module that provides four 25-GbE (SFP28) MACsec capable ports.
You need the following tools and materials to install a VIM module:
- ESD-preventive wrist strap
- Phillips head screwdriver
Remove a VIM module
Use the following instructions to remove a VIM module.
- Attach the ESD wrist strap to your wrist and connect the metal end to an appropriate ground point on the rack.
- Ensure that the switch is completely powered down.
- Remove the screws that secure the VIM module in the VIM slot using the Phillips head screwdriver.
VIM Module Inserted in Slot
- 1 = VIM module retaining screw locations
- Slide the VIM module out of the VIM slot and set it aside.
Replace a VIM module
Use the following instructions to replace a VIM module.
- Remove the VIM cover (if necessary) by removing the screws that hold the cover plate over VIM slot, using the Phillips head screwdriver.
Removing a slot Cover Plate (VIM slot cover shown)
- Remove the new VIM module from its anti-static packaging.
- Install the VIM module in the switch:
- Carefully slide the VIM module into the switch.
- Insert and tighten the retaining screws you previously removed, using the Phillips head screwdriver.
