Extreme 7720 Technical Specifications
External Interfaces
Ports
  • 32 x QSFP+QSFP28 40Gb/100Gb ports
  • 124 x 10G/25G ports using break-out cables
  • 1 x Serial console port RJ-45
  • 2 x 10/100/1000BASE-T out-of-band management port (only the first port is used for out-of-band management)
  • USB Type A storage port
Power Supplies
  • Modular 800W AC power supply (up to 2 PSUs)
  • Modular 800W DC power supply (up to 2 PSUs)
  • Front-Back and Back-Front airflow options
Fan Tray
  • 6 fan modules, support one fan redundancy
Dimensions
  • 17.3in W/22.44in D/1.7in H (44.0cm/57.0cm/4.3cm)
Weight
  • 16.3 lb (7.4 kg) no PSU/19.9 lb (9.0 kg) with two PSUs
Performance
  • Line rate 6.4 Tbps Switching Capacity (3.2 Tbps ingress, 3.2 Tbps egress)
  • Forwarding Rate: 2000 Mpps
  • Typical Latency: 800 ns
CPU/Memory
  • 8-core Processor
  • 16GB DDR4 memory
  • 128GB SSD memory
Packet Buffers
  • 32MB
Operating ConditionsEnvironmental Operating Temperature
Front-to-back:
  • 0°C (32°F) to 50°C (124°F) at sea level
  • 0°C (32°F) to 45°C (113°F) up to 1800 m (6000ft)
  • 0°C (32°F) to 40°C (104°F), up to 3000m (10000 ft)
Back-to-front:
  • 0°C (32°F) to 45°C (113°F) at sea level
  • 0°C (32°F) to 40°C (104°F) up to 1800 m (6000ft)
  • 0°C (32°F) to 35°C (95°F) up to 3000m (10000 ft)
Weights and Dimensions of Accessories
ModelWeightDimensions
XN-FAN-001-F: Fan unit, front-to-back or XN-FAN-001-R: Fan Unit back-to-front
0.14 kg (0.31 lb)
Height: 4.0 cm (1.57 in)
Width: 4.0 cm (1.57 in)
Length: 13.4 cm (5.28 in)
XN-4P-RKMT298 - Four-post rack mount kit (included with switch)
2.63 kg (5.8 lb)
Height: 2.1 cm (0.83 in)
Width: 4.4 cm (1.73 in)
Length: 63.0 cm - 90.0 cm (24.80 in - 35.43 in)
XN-2P-RKMT299 - Two-post rack mount kit (ordered separately)
2.8 kg (6.17 lb)
Height: 4.44 cm (1.75 in)
Width: 2.0 cm (0.79 in)
Length: 67.93 cm - 93.24 cm (26.76 in - 36.73 in)
Console Cables
Description
XN-RJ45-DB9-CONSOLE-CBLRJ45 to DB9 Console cable (6ft)
XN-RJ45-USBA-CONSOLE-CBLRJ45 to USBA Console cable (6ft)*
XN-RJ45-USBC-CONSOLE-CBLRJ45 to USBC Console cable (6ft)*
* The cable might require an FTDI software driver on some operating systems.
