System Status LEDs
System status LEDs are located on the front of the switch. The following table describes the colors and the states for the LEDs.
Label or TypeColor/StateMeaning
PSU1, PSU2
(Power Supplies)
Solid greenPSU is installed and providing power
Solid amberPSU is installed but input power is disconnected or unit fault detected
OffPSU is not installed
FANSolid greenAll fans operating normally
Solid amberA fan has been removed or fault detected
OffNo power to fan modules
SYS
(System)
Note: The system status LED is solid green to indicate normal operation when the switch is running Fabric Engine.
Slow blinking greenSystem loaded properly and is ready
Solid amberEither the PSU or fan or both are faulty, not present, or the system has not loaded properly
OffCPU power is off
PWR
(Power)
Solid greenNormal operation
Blinking greenSystem in reset
OffUnit not operational
SECURESolid blueAuthentication complete
Very slow blinking blue (0.25Hz)Bypass authentication (debug only)
Fast blinking blue (4Hz)Authentication failed
Slow blinking blue (1Hz)Authenticating or updating images
OffAuthentication begin or fault
