Power Specifications
This topic describes power supply specifications, power consumption, and heat dissipation.
Power Supply Specifications
The following table includes power supply specifications for the switch.
800W AC PSU
XN-ACPWR-800W-F/R
800WDC PSU
XN-DCPWR-800W-F/R
Dimensions3.15 in W x 1.57 in H x 8.11 in D (8.0 cm x 4.0 cm x 20.6 cm)3.15 in W x 1.57 in H x 8.11 in D (8.0 cm x 4.0 cm x 20.6 cm)
Weight1.79 lb (0.81kg)1.85 lb (0.85kg)
Voltage Input Range100VAC-140 VAC/200VAC-240 VAC-48VDC to -60VDC
Line Frequency Range50Hz– 60HzN/A
PSU Input SocketIEC320 C14Terminal Block
PSU Output CordIEC320 C13N/A
Operating Conditions0°C–55°C operation0°C–55°C operation
Power Consumption
The following table includes power consumption information for the switch.
Operating ModeTest Conditions Power Consumption
Fan DutyTraffic LoadPort StatusPacket Length (Bytes)Dual Power: PSU1Dual Power: PSU2Single Power: PSU1
Empty mode85%N/AUpN/A152.6 W145.5 W285.9 W
Standby mode85%N/AUpN/A157.6 W151.5 W 297.2 W
Typical mode 85%70% Up1,518 165 W159.8 W 313.6 W
Stress mode 100% 100% Down256 207.8 W204.5 W 406.0 W
Power Consumption and Heat Dissipation
The following table includes power and heat dissipation information for the switch.
Switch Model
Minimum Heat Dissipation (BTU/hr)
(Idle,no ports linked)
Minimum Power Consumption (Watts) (Idle, no ports linked)
Maximum Heat Dissipation (BTU/hr) (Fans high,
all ports 100% traffic)
Maximum Power Consumption (Watts) (Fans high,
7720-32C-AC (F/R)972 BTU/hr285W1340 BTU/hr393W
7720-32C-DC (F/R)975 BTU/hr286W1381 BTU/hr405W
