7720 Series Installation Guide
> Remove and Replace Components
Extreme Networks, Inc. September 01, 2026
Introduction to the Extreme 7720 Installation Guide
New in this Guide
Extreme 7720 Overview
Extreme 7720 Switch Features
Port Subdivisions
Manage Your Switch
Universal Ethernet Ports
Secure Boot
Fan Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
800 W AC Power Supplies
800 W DC Power Supplies
Build Stacks
Introduction to Stacking
Build Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
SummitStack Terms
Plan to Create Your Stack
Enable and Disable the Stacking Support Option
Recommendations for Placing Switches for Stacked Operation
Recommendations for Configuring Stacks
Combine Switches from Different Series
Select Stacking Cables
Use the Extreme Stacking Tool
Set up the Physical Stack
Connect the Switches to Form the Stack Ring
Examples of Valid Stacking Configurations
Example: Basic Stack with Four Switches
Example: Basic Stack with Eight Switches
Example: Stacked Switches across Several Racks
Connect Your Stack to the Management Network
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Log In for the First Time on Switch Engine
Change the Switch OS via the Bootloader Menu
Change the Switch OS via the Startup Menu
Log In for the First Time on Fabric Engine
Remove the Device from the Rack
Remove a Switch from a Four-Post Rack
Remove a Switch from a Two-Post Rack
Replace Power Supplies
Power Supply Airflow Direction Requirements
Replace a Power Supply
Replace Fan Modules
Fan Airflow Direction Requirements
Replace a Fan Module
Monitor the Switch
System Status LEDs
RJ-45 Management Port LEDs
QSFP28 Port LEDs
800 W AC Power Supply LEDs
800 W DC Power Supply LEDs
Technical Specifications
Extreme 7720 Technical Specifications
Acoustic Noise and Fan Speed
Mean Time Between Failures
Power Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
Safety Information
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
Regulatory Information
CE statement
EMC Warnings
China and Taiwan: Restriction of Hazardous Substances (ROHS)
Canadian requirements
China CCC statement
Australia (RCM)
Federal Communications Commission (FCC) Notice
Germany statement
KCC statement (Republic of Korea)
Japan (VCCI Class A)
Japan power cord
Use the information in the following topics to remove or replace components.
Section contents:
Replace Fan Modules
