If your device does not come with an installed internal power supply, you can install one or two power supplies. All installed power supplies must blow air in the same direction (front-to-back or back-to-front) and must match the airflow direction of the installed fan modules.
The following 800 W AC or DC internal power supply units (PSUs) are available for the switch:
For installation instructions, see Replace Internal Power Supplies.
