List of Stacking Terms describes the terms used for the SummitStack feature. These terms are listed in the recommended reading sequence.
| Term | Description |
| Stackable switch | An Extreme Networks switch that provides two stacking ports and can participate in a stack. |
| Stacking port | A physical interface of a stackable switch that is used to allow the connection of a stacking link. Stacking ports are point-to-point links that are dedicated for the purpose of forming a stack. |
| Native stacking | A stacking configuration in which stack members are connected using either designated Ethernet data ports or dedicated stacking connectors. |
| Alternate stacking | A stacking configuration in which stack members are connected using 10-Gbps Ethernet data ports that have been configured for stacking. These ports are located either on the switch itself or on option cards installed on the rear of the switch. |
| Stacking link | A cable that connects a stacking port of one stackable switch to a stacking port of another stackable switch, plus the stacking ports themselves. |
| Node | A switch that runs the Switch Engine operating system and is part of a stack. Synonymous with stackable switch. |
| Stack | A set of stackable switches and their connected stacking links made with the intentions that: (1) all switches are reachable through their common connections; (2) a single stackable switch can manage the entire stack; and (3) configurable entities such as VLANs and link trunk groups can have members on multiple stackable switches. A stack consists of all connected nodes regardless of the state of the nodes. |
| Stack topology | A contiguously connected set of nodes in a stack that are currently communicating with one another. All nodes that appear in the show stacking command display are present in the stack topology. |
| Stack path | A data path that is formed over the stacking links for the purpose of determining the set of nodes that are present in the stack topology and their locations in the stack. Every node is always present in a stack path whether or not stacking is enabled on the node. |
| Control path | A data path that is formed over the stacking links that is dedicated to carrying control traffic, such as commands to program hardware or software image data for software upgrade. A node must join the control path to fully operate in the stack. A node that is disabled for stacking does not join the control path, but does communicate over the stack path. |
| Active node | A node that has joined the control path. The active node can forward the control path messages or can process them. It can also forward data traffic. Only an active node can appear as a card inserted into a slot when the show slot {slot {detail} | detail } command is executed on the primary node of the stack. |
| Active topology | A contiguous set of active nodes in a stack topology plus the set of stacking links that connect them. When an active topology consists of more than one node, each node in the active topology is directly and physically connected to at least one other node in the active topology. Thus, the active topology is a set of physically contiguous active nodes within a stack topology. |
| Candidate node | A node that is a potential member of an active topology, or an active node that is already a member of an active topology. A candidate node may or may not be an active mode – that is, it may or may not have joined the control path. |
| Node role | The role that each active node plays in the stack – either primary, backup, or standby. |
| Primary node | The node that is elected as the primary node in the stack. The primary node runs all of the configured control protocols such as OSPF (Open Shortest Path First), RIP (Routing Information Protocol), Spanning Tree, and EAPS (Extreme Automatic Protection Switching). The primary node controls all of its own data ports as well as all data ports on the backup and standby nodes. To accomplish this, the primary node issues specific programming commands over the control path to the backup and standby nodes. |
| Backup node | The node assigned to take over the role of primary if the primary node fails. The primary node keeps the backup node's databases synchronized with its own databases in preparation for such an event. If and when the primary node fails, the backup node becomes the primary node and begins operating with the databases it has previously received. In this way, all other nodes in the stack can continue operating. |
| Standby node | A node that is prepared to become a backup node in the event that the backup node becomes the primary node. When a backup node becomes a primary node, the new primary node synchronizes all of its databases to the new backup node. When a node operates in a standby role, most databases are not synchronized – except those few that directly relate to hardware programming. |
| Acquired node | A standby or backup node that is acquired by a primary node. This means that the primary node has used its databases to program the hardware of the standby or backup node. The standby or backup node has acted as a hardware programming proxy, accepting the instructions of the primary node to do so. An acquired backup node maintains the databases needed to reflect why the hardware is programmed as it is. However, a standby node does not. An acquired node can be re-acquired (without a reboot) by the backup node only when the backup node becomes the primary node, and only when both the backup and standby nodes were already acquired by the same primary node at the time of its failure. |
| Data ports | The set of ports on a stackable switch that are available for connection to your data networks. Such ports can be members of a user-configured VLAN or trunk group. They can be used for Layer 2 and 3 forwarding of user data traffic, for mirroring, or other features you can configure. Data ports are different from stacking ports. |
| Failover | The process of changing the backup node to the primary node when the original primary node has failed. When a primary node fails, if a backup node is present, and if that node has completed its initial synchronization with the primary node, then the backup node assumes the role of primary node. The standby nodes continue their operation and their data ports do not fail. |
| Hitless failover | A failover in which all data ports in the stack, except those of the failing primary node, continue normal operation when the primary node fails. |
| Node address | The unique MAC address that is factory-assigned to each node. |
| Node role election | The process that determines the role for each node. The election takes place during initial stack startup and elects one primary node and one backup node. An election also takes place after a primary node failover, when a new backup node is elected from the remaining standby nodes. |
| Node role election priority | A priority assigned to each node, to be used in node role election. The node with the highest node role election priority during a role election becomes the primary node. The node with the second highest node role election priority becomes the backup. |
| Operational node | A node that has achieved operational state as a card in a slot. The operational state can be displayed using the show slot {slot {detail} | detail }command. |
| System uptime | The amount of time that has passed since the last node role election. You can display the system uptime by entering the show switch {detail } command on the primary node. |
| Stack segment | A collection of nodes that form a stack topology. The term is useful when a stack is severed. Each severed portion of the stack is referred to as a stack segment. |
| Stack state | A state assigned by the stack to a node. You can display the stack state by entering the show stacking command. |
| Easy Setup | A procedure that automatically configures the essential stacking parameters on every node for initial stack deployment, and then automatically reboots the stack to put the parameters into effect. The choice to run Easy Setup is offered when you run the enable stacking {node-address node-address} command and the essential stacking parameters are unconfigured or inconsistent. It can also be invoked directly by running the configure stacking easy-setup command. |
