Install Optional Components
After the switch is secured to the rack, install optional components.
Extreme Networks switches support the use of pluggable transceivers and cables in the SFP, SFP+, SFP28, QSFP+, and QSFP28 formats.
For a list of the optical components supported with Extreme Networks devices, see the Extreme Optics website.
Pluggable Transceiver Modules
Extreme Networks offers several optical transceiver modules for transmitting and receiving data over optical fiber rather than through electrical wires.
Optical Cables
Direct-attach copper and fiber cables provide connections between populated SFP, SFP+, SFP28, QSFP+, and QSFP28 ports.
Breakout cables
The copper breakout cables are terminated with optical connectors and are available in 1m, 3m, 5m, or greater lengths. No additional connectors or cabling are required when using the copper breakout. When using the fiber breakout cables, additional 10Gb optics are required.
For Extreme 7720 switches running either Fabric Engine or Switch Engine, interfaces 0/1 through 0/27 and 0/29 through 0/32 support up to 4 10GbE, 4 25GbE, 1 40GbE, or 1 100GbE ports each in breakout mode when using the appropriate optics. Interface 0/28 cannot be partitioned, but it supports 1 40GbE or 1 100GbE port.
See the Extreme Optics website to determine the appropriate optics.
