Reset the AP
Perform a reboot or factory reset to resolve minor or temporary issues. A reboot deletes the logs, but preserves all of the configuration settings. A factory reset deletes your configuration settings and restores the AP to the original factory settings.
See LED Descriptions for an explanation of LED display.
The Reset button is located next to the Console port.
Reset Port
AP4020 reset port
Table 1. AP4020 Reset Port
ItemPortDescription
1ResetUsed to reboot the AP or do a factory reset.
Perform a Reboot
A reboot, also called a power cycle, deletes the logs, but preserves all of the configuration settings. It also applies firmware upgrades and is often done to clear minor issues such as software issues or if the AP is not responding.
There are two ways to reboot the AP:
Perform a Factory Reset
Perform a factory reset only when you want to restore the AP to its original factory settings.
There are two ways to factory reset the AP:
