The AP4020 supports both 802.3at PoE and 802.3bt PoE.
802.3bt PoE is typically used with the 5W USB. 802.3af is not an operational power mode; it is typically used only during the onboarding stage.For more information about the technical specifications, see the AP4020 Data Sheets found here.
Section contents:
