The following table lists the antenna gains for your access point grouped by operational mode and radio. Use this information as you plan your installation to maximize the AP's efficiency.
Antenna gain is a measure of an antenna's efficiency to convert power into radio waves. It relates the intensity of an antenna in a given direction to the intensity that is produced isotropically or by an antenna that radiates equally in all directions and has no losses.Only a professional installer should ever set the antenna gain. For more information, see Wireless Controller, Service Platform and Access Point CLI Reference Guide.
| Radio 1 | Radio 2 | Radio 3 | IoT Radio | |
| Mode 1 | 2.4G - 3.2dBi | 5G - 5.1dBi | 6G - 6dBi | 4.2dBi |
| Mode 2 |
2.4G - 3.2dBi 5G - 4.2dBi 6G - 4.4dBi | 5G - 5.1dBi | 6G - 6dBi | 4.2dBi |
| Mode 3 | 5G - 4.2dBi | 5G - 5.1dBi | 6G - 6dBi | 4.2dBi |
| Mode 4 | 2.4G - 3.2dBi 5G - 4.2dBi 6G - 4.4dBi | 5G - 5.1dBi | 2.4G - 3.2dBi | 4.2dBi |
| Mode 5 | 5G - 4.2dBi | 5G - 5.1dBi | 2.4G - 3.2dBi | 4.2dBi |
| Mode 6 | 6G - 4.4dBi | 5G - 5.1dBi | 6G - 6dBi | 4.2dBi |
