Power Options
The AP5020
supports the following power options:
- Power draw: 802.3at PoE: typical
21W, max. 25.5W (802.3at profile) w/o PoE out or USB
- Power draw: 802.3bt: max. 35W
with 5W USB
- 12V DC/3A. DC power has priority
when both DC and PoE power sources are available
- PoE failover or optional Power
Sourcing Equipment (PSE ) out is supported
Power Sourcing
Equipment (PSE) is disabled by default.
- With DC power in, USB 5W power is
supported
