The AP5020 has several ports and hardware features that connect the AP to your network or are used to access a feature. Use the information in the following sections to locate these ports.
The following table and graphic show the available ports on the front of the AP.
| Item | Port | Description |
| 1 | 2.0 USB type A port, 5V/500mA with POE.at or 5V/1000mA with POE.bt | Used with a thumb drive or other external device. |
| 2 | Console port | Micro USB console port for a serial connection between your
management system and the access point. Use the port when you
troubleshoot the AP. The best practice is to use the Extreme
Networks micro USB cable (ACC-WIFI-MICRO-USB). When you connect
to the device, the management station must have a VT100
emulation program, such as the terminal emulator TeraTerm Pro or
Hilgraeve HyperTerminal. Set your baud rate to 115200.
Note: The console
port can only be used with the Extreme Networks console
cable. You will damage the AP if you use another cable.
| 3 | Kensington security slot | A security feature that prevents someone from removing the AP. This is an optional task. |
| Item | Description | Use |
| 1 | 12VDC | 12-volts of direct current. |
| 2 | ETH1 port | Ethernet port. |
| 3 | ETH0/PoE port | Ethernet port. |
AP5020 Rear Ports and Connections
