Micro USB Console Port Information
Use the micro-USB console port to make a serial connection between your management system and the access point. You can order a micro USB console adapter for your access point using the part number ACC-WIFI-MICRO-USB.
When you connect to the Micro USB console port, the management station from which you connect to the device must have a VT100 emulation program, such as TeraTerm Pro (a free terminal emulator) or Hilgraeve HyperTerminal (provided with Windows operating systems from XP forward).
Micro-B model Console Port Pin Information
Image of gray micro USB port pins stacked aside each other with numerical call outs from 1 to 5.
Table 1. Micro-B USB Pin Information
Pin NumberPin Name and Description
1NC
2R×D (input to access point)
3T×D (output to terminal)
4Signal (GND)
5Signal (GND)
