The Universal Compute Platform enables the creation of additional logical interfaces to support multi-homed deployments. Use the Create New Interface wizard to configure the required settings. The following table describes the settings.
| Field | Description |
| Name | Name of the interface. |
| Mode | Describes how traffic is forwarded on the interface topology. Options are:
| VLAN ID | ID for the virtual network. |
| Tagged | Indicates if the interface tags traffic. When traffic is tagged, the VLAN ID is inserted into the packet header to identify which VLAN the packet belongs to. Tagging can identify the port or interface to send a broadcast message to. |
| Port | Physical port on the Universal Compute Platform for the interface. |
| Management Traffic | Enable or disable Management Traffic through this interface. Enabling management provides access to SNMP (v1/v2c, v3), SSH, and HTTPs management interfaces. |
| MTU | Maximum Transmission Unit (MTU). Standard is 1500 bytes. Fixed value. |
| Layer 3 | |
| IP Address | For an Admin topology, the Layer 3 check box is selected automatically. The IP address is mandatory for a Physical topology. This allows for IP Interface and subnet configuration together with other networking services. |
| CIDR | CIDR field is used along with IP address field to find the IP address range. |
| FQDN | Fully-Qualified Domain Name |
| VRRP | Supports load balancing and high-availability functions for the Universal Compute Platform cluster. You can also assign VRRP settings to create an IP alias that provides access to the underlying management interface for an application instance.
Note: In a stand-alone configuration, configure priority and router ID with a numeric value. However, in a standalone configuration, the specific value is not important. These attributre definitions are important in multiple-node configuration.
