VRRP IPs must be within the same segment as configured for the interface.
VRRP IP addresses must not overlap with any other address in use in the segment.
In a stand-alone configuration, configure priority and router ID with a numeric value. However, in a stand-alone configuration, the specific value is not important. These attribute definitions are important in a multiple-node configuration.
For some applications, access to their management interface, or user interface, is configured as a pass-through Universal Compute Platform data interface by leveraging VRRP to create an alias IP. Make sure that the VRRP IP addresses that you use are not in conflict with any other IP in the segment, including addresses that are assigned by the application.The VRRP configuration relates to the number of services you are exposing. Configure a VRRP IP address (VIP) for each service.
| Single Node (Port #) | |
| Data Port (optional) | Node Port IP /CIDR |
| VLAN | VLAN Tagged/Untagged |
| Port type | Physical |
| VRRP (required) | |
| VRRP IP address (VIP) | VIP address |
| Priority | Numeric Value |
| Router ID | ID (1) |
