To onboard a Universal Compute Platform cluster into ExtremeCloud IQ use the ExtremeCloud IQ Quick Add function:
From the ExtremeCloud IQ main navigation pane, select (Manage), and then select Devices.
Select (Add) and then select Quick Add Devices > Manage your devices directly from the cloud.
In the Serial Number field, enter the serial number for one node in the cluster.
Add Cluster to ExtremeCloud IQ
The Device Make field displays.
From the Device Make menu, select Universal Appliance.
Select Add Devices.
The full cluster is added based on the serial number of a single node in the cluster.
To view details about the cluster, select the Host Name link.
Select Actions > Applications > ExtremeCloud IQ Manage.
ExtremeCloud IQ Actions menu
This initiates the action for ExtremeCloud IQ OPs to deploy a Regional Data Center (RDC) for the cluster.
Fill out the online form:
Required fields are noted with an asterisk.
Customer Information
Primary Technical Contact
Secondary Technical Contact
Notification List—Provide a
list of email addresses for notification.
Nightly Backup
Scheduled Upgrades
RDC Name—Provide a
meaningful name, up to 6 characters. The system will verify that the
name is available.
IP Address Mapping—Provide
the mapping between the external Public IP Address to the internal
virtual VRRP IP Address for each service set.
ExtremeCloud IQ Deploy a Cluster Form
Select Deploy.
A ticket is generated for ExtremeCloud IQ OPs. Operations personnel will provide an estimate for the expected deployment schedule.
During deployment, the OPs team will do the following:
Deploy ExtremeCloud IQ software to the
on-premises hosts
Validate the deployment to ensure that the site is deployed and operating correctly
Once validated, OPs will provide notification of readiness
Provide the installation token that enables customers to create accounts directly on the newly deployed ExtremeCloud IQ private Regional Data Center (RDC).
You can view the status of the deployment process from the Application Status column on the Device List
