Install ExtremeCloud IQ Engine
ExtremeCloud IQ is the only available engine for an ExtremeCloud Edge - Managed Orchestration deployment. Install the engine once from a single node.
Installing the ExtremeCloud IQ engine prepares the cluster to receive the ExtremeCloud IQ application but does not install the application. Extreme CloudOps completes the application installation after you onboard the cluster and register your account.
  1. Go to Engines.
  2. From the ExtremeCloud IQ pane, select Install.
    The system is prepared to receive the ExtremeCloud IQ application(s). Please proceed to onboard and register the cluster.
Installed ExtremeCloud IQ Engine Instance
Installed ExtremeCloud IQ engine instance
An ExtremeCloud Edge - Managed Orchestration deployment of ExtremeCloud IQ must be configured in a cluster of three or more nodes in multiples of three. The minimum number of cluster nodes is three for ExtremeCloud IQ only, and six nodes if you're also deploying other applications.
