ExtremeCloud Edge v5.15.01 Managed Orchestration Deployment Guide
Appendix
> Appendix C: Node Additions and Replacements
Extreme Networks, Inc. September 28, 2026
Abstract
Preface
Introduction
Managed Orchestration Cluster
Kubernetes
Supported Appliances for Managed Orchestration
Deployment Responsibilities
Requirements
ExtremeCloud Edge Planning
Firewall Access for Critical Settings
DHCP Client
Availability Zones
Prerequisites for ExtremeCloud Edge Installation
IP Addresses
VRRP Configuration
Reserved IP Addressing
Port Information for Firewalls
Source Address Information
Configure the Deployment
Connect to the Appliance through the Console Port
Connect to the Appliance through the ICC1 Port
Run the Basic Configuration Wizard
Upgrade the Appliance Software
IP Address Configuration
Configure VRRP (VIP)
Configure the Cluster Settings
Run Readiness Assessment
Install ExtremeCloud IQ Engine
Network Service Configuration
Validate the Cluster
Onboard Cluster to ExtremeCloud IQ
Account Registration
Cloud Visibility
Configure Persistent Connection to ExtremeCloud
Appendix
Appendix A: ExtremeCloud IQ - Site Engine Integration with ExtremeCloud Edge
Appendix B: Migrate Virtual IQ Account
Export VIQ Account
Import VIQ Account
Add Nodes
Replace a Node
Use the procedures in this Appendix if you need to add new nodes or replace a node that has failed.
