Configure AP Templates
Before you begin, create a network policy for the APs (see Configure Device Templates). You can also configure an AP template directly from the Common Objects tab.
Create AP device templates with default settings for all APs, and settings that ExtremeCloud IQ applies when APs are onboarded. Default AP settings can then be modified individually as required. AP templates enable quick AP deployment, with most of the port settings already applied by the associated template. Some devices have extra possible configuration options, depending on the device model.
When AP device templates and auto-provisioning rules (see Configure Auto-Provisioning) are both in place for an AP when it is onboarded, the auto-provisioning rules are applied and the device template is ignored.
Use this task to configure an AP device template.
  1. Go to Configure > Common Objects > Policy > AP Template.
  2. Select an existing AP Template, and then select Edit, or select Add.
    To delete the selected template, select Delete.
  3. For a new template, enter a name, and for an existing template, edit where necessary.
  4. Select the ports or interface icons on the template graphic.
    1. To select all of the ports and interfaces, choose Select All Ports.
    2. To deselect all of the ports and interfaces, select Deselect All Ports.
  5. To Assign an Ethernet port profile, see Assign an Ethernet Port Profile.
  6. To configure Wireless Interfaces, see Configure Wireless Interfaces for an AP Template.
  7. To configure Wired Interfaces, see Configure Wired Interfaces for an AP Template.
  8. To configure SES-imagotag, see Configure Electronic Shelf Labeling.
  9. To configure Advanced Settings, see Configure AP Device Template Advanced Settings.
  10. Select SAVE TEMPLATE.
Continue configuring the network policy.
