Configure Device Credentials Policy Settings
ExtremeCloud IQ uses device credentials for remote access to devices through Telnet, SSH, or console connections. If you do not configure the Administrator and Read Only Administrator accounts, global device management settings apply.
If you configure a new administrator account, the new account replaces the default account.
This task is part of the network policy configuration workflow. Use this task to configure NTP Server Policy Settings for a network policy.
  1. Go to Configure > Network Policies.
  2. Select an existing network policy, and then select Edit, or select Add to create a new policy.
  3. From the Policy Settings menu, select Device Credentials.
  4. Configure the following settings:
    Table 1. Device Credentials
    SettingDescription
    Administrator Account
    Admin NameType the name of the Administrator account.
    PasswordType the password for the Administrator account.
    Show PasswordSelect the check box to show the password.
    Admin NameType the name of the Read Only Administrator account.
    PasswordType the password for the Read Only Administrator account.
  5. Select SAVE.
