External administrators must have an ExtremeCloud IQ account before they can be added.| Field | Description | |
| Email Address | The email address of the administrator. | |
| Name | The name of the administrator (internal admin only). | |
| Idle Session Timeout | The number of minutes before a session times out (internal admin only). | |
| Choose a Role—Assign a role to each admin. | ||
| Installer | Designed to work with the mobile app, and has limited privileges based on the built-in limitations of the app. If you log into ExtremeCloud IQ as an admin with Installer privileges using the standard web interface, the Management, Insights, and Configuration tools are read-only with the following exceptions:
| Guest Management | Has access only to the guest management admin interface. This is mainly for employees who need to create user accounts for guests, contractors, and employee personal devices to enable access to the wireless network. | |
| Application Operator | Can view status information about client devices and supported APs and change roles for a client device. this role cannot see other menus, or make configuration changes to the network. | |
| Observer | Has read-only access to most of the ExtremeCloud IQ interface. This role does not have access to the account and license or subscription management functions. The difference between Observer and Monitor is the Monitor role has write access to the Tools tab and read access to the rest of the network. The Observer has read-only access. | |
| Monitor | Has full read-write access to system Tools located at Manage > Devices > Utilities > Tools and restricted (read-only) access to the remaining tabs. With full access to the Tools tab, the monitor role can diagnose client issues, escalate issues, and mark issues as resolved. | |
| Administrator | Has full read-write access to ExtremeCloud IQ and your network. This is the only role that can create and manage administrators and ExtremeCloud IQ licenses. | |
| Help Desk | Has full access to the Tools tab. They can diagnose client issues, escalate issues, and mark issues as resolved, and search by user name to see details for a user, or by MAC address to see details for a client. | |
| Operator | Has full write access, but cannot manage accounts and licensing. An operator can also update the network map (located on the Manage > Planning tab) to add a building or a floor to any location, unless they are restricted to a single location. Note: Local operators cannot view alarms for locations they cannot access.
| Access
Scope—Available only when the site isolation feature is
enabled for the VIQ. Assign the locations to which the administrator has access. Access restrictions by location are based on the locations defined in your network map. This scope applies to all roles. | ||
| All Sites | The administrator can create and edit objects for all sites (global). | |
| Custom | The administrator can create objects only for
specified sites. Select the down arrow to display the Assign Sites menu.
Select the sites to which the administrator will have access. Clear the
corresponding check box to remove access to a site. To specify global read only access for the administrator, select Read Only, under Global Permissions. | |
| Global Permissions—Available only when you select Custom for the Access Scope, and the site isolation feature is enabled for the VIQ. | ||
| Read & Write | The administrator can edit global objects. | |
| Read Only | The administrator can view the settings for global objects, but cannot make changes. | |
