Configure Management Options
For more information about the settings, see Management Options.
Use these settings to control how administrators are authenticated and how they access the devices they manage.
  1. Go to Configure > Common Objects > Network > Management Options.
  2. Select an existing management object, and then select Edit, or select Add.
  3. Enter a Name.
  4. Enter an optional Description.
  5. Configure Forwarding Engine Control Management Options.
  6. Configure System Settings Management Options.
  7. Configure Authentication Settings Management Options.
  8. After you have completed all the relevant sections, select SAVE.
