Create a Certificate and Key
Before generating a certificate, make sure the time and date on the ExtremeCloud IQ clock are accurate. Otherwise, the certificate might be rejected during validation because the starting date has not occurred or the expiration date has passed.
Use this task to create a certificate and key.
  1. Select the plus sign.
  2. Create one of the following types of certificates:
    • ExtremeCloud IQ CA: Select to generate your own Certificate Authority (CA) certificate. See Create an ExtremeCloud IQ Certificate of Authority.
    • Server CSR: Select to generate a certificate that consists of three parts used during the verification process. The first part describes the content of the certificate. The second part contains the server public key. The third part consists of the same fields hashed with the server message digest, or public key, and then encrypted with the issuing CA digital signature (for example, the ExtremeCloud IQ CA) private key. See Create a CSR for a Server.
    • Concatenate an existing certificate and private key: Select this option when working with captive web portals. One option in a captive web portal configuration is to secure wireless client traffic using HTTPS. The type of web server that an Extreme Networks device supports requires the server certificate be concatenated with an unencrypted private key that corresponds with the certificate's public key. You can concatenate an existing server certificate and private key or generate a new self-signed server certificate that already has the private key and certificate concatenated. See Concatenate an Existing Certificate and Private Key.
    • Self-signed certificate: Select to generate a new self-signed server certificate that already has the private key and certificate concatenated. See Create a Self-Signed Certificate.
  3. Select Save.
  4. You can also import a certificate or key.
