Multi-Link Operation (MLO) is a core capability in Wi-Fi 7 that allows devices to simultaneously connect to and use multiple frequency bands (2.4 GHz, 5 GHz, and 6 GHz) at the same time. MLO supports various modes, including:
Simultaneous Transmit and Receive (STR): The device transmits and receives data on multiple links at the same time.
Nonsimultaneous Transmit and Receive (NSTR): The device can only transmit or receive on one link at a time, but it can switch between links quickly.
MLO is supported on the AP4020, AP4020X, AP4020FX, AP4060, AP4060X, and AP5020 switches. To enable MLO, the following conditions must be met:
Security for the SSID must be WPA3(SAE)
The 802.11k protocol must be enabled
Transition Mode must be disabled
The 2.4 GHz, 5 GHz, and 6 GHz frequency bands must enabled simultaneously
