All customers must generate and install an activation license. After you install the CE deployment, use this procedure to generate and install the activation package.
- Obtain the Locking ID of the CE instance:
                    - Log in to the CE instance.
 - Under Upload Activation License , copy the Serial Number (Locking ID) value.
If you plan to onboard to ExtremeCloud IQ, copy the
MAC Address value too as you will need it during cloud onboarding.
                  - Obtain the activation file:
                    - Log in to the Extreme Networks Support Portal .
 - Go to   and select the CE1000, CE2000, or CE3000 Voucher ID line item from the list.
 - On the Voucher Details page, select Generate Activation Key .
 - Provide the serial number for the CE activation.
 - Select the box to accept Terms and Conditions and select Submit to generate the activation file.
 - Download the activation file.
                  - Install the activation file:
                    - If you signed out of CE container, sign back in.
 - Upload the license file to the Upload Activation License pane.
