Run the configuration wizard to connect ExtremeCloud IQ Controller to the network, and to assign basic network settings such as the admin password, DNS servers, time servers, and default gateway.
For each category, the wizard displays the default setting and asks whether you accept the default setting. The following conventions apply:
You must press the <Enter> key after each line entry.
Round brackets ( ) represent choices and square brackets [ ] represent the default selection that gets applied if you press <Enter> without making a selection. For example, (y|n) [y] where y and n are options and y is the default.
For IP address and subnet settings, if you don't want to use the default, enter the desired IP address or netmask and then press <Enter>.
