Before you install the CE container application, make sure that you've done the following:
Licensing Requirements
Purchase the required SKUs for your deployment. Check with your Extreme representative on SKU requirements.
Download the installation image for your application from the portal at Downloads/ExtremeCloud/Extreme Cloud IQ Controller.
Universal Compute Platform Requirements
Reserved IP Address Ranges
A CE deployment requires the reservation of the following IP address ranges.
| Purpose | Range | Description |
| ExtremeCloud IQ Controller Application Network | 172.17.0.0/24 172.31.0.10/28 10.0.2.0/24 | These ranges are used for internal controller application functions. These ranges are non-configurable. |
| Pod Network | The POD segment that you assigned on host (The default range is 10.96.0.0/16) | This is the segment range for POD Network that was assigned during host cluster creation. Please review cluster configuration on host to confirm. |
