The Anomalies table is interactive, and displays the following information for each anomaly:
This column appears only when the Exclude Muted toggle is off. The possible values for this column are Yes and No.
You can display the anomalies in ascending or descending order by column, except for the Interface column. You can also search for anomalies by device, issue, site, or anomaly type. Use the Items per page menu to specify the maximum number of results to show, per page.
To download a CSV file that contains the same information, select
Some recurring anomalies are not problematic and you can mute or dismiss them. Select the corresponding check boxes for these anomalies, and then select or .
When Exclude Muted is enabled, all existing and future anomalies of the selected type and location are hidden. For example, muting a PoE Stability anomaly for Site A hides all current and future anomalies of the PoE stability type for Site A.Section contents:
